DesertDogs
Nov 27, 2019Explorer
rhagfo wrote:MFL wrote:
While many 3/4 ton trucks can handle nearly the same load as a 1 ton SRW, by using after market devices to level the load, it is best to just get the 3500 to start with, if needed, when buying new. In your case, the FW you are considering, on your profile, you need the 3500.
Jerry
X2
36' 5er is not really short, and the one the OP is looking at has a GVWR of 16,000#, the only thing that will help you stick with a 3500 SRW is that this 5er has a payload of 3,600#.
320 GK Specs
GVWR : 16,000
Dry Weight : 12,400*
Cargo Carrying : 3,600
Hitch Weight : 2,600 (21% of dry)
Starting from dry weight if you only add 2,000# of stuff now the 5er's GVW is 14,400# X 21% = 3,024, I would expect the pin percentage to be more like 23% to 25% so up to 3,600# just for the 5er on the TV.
Best be looking at the 3500, and might even consider a DRW.
Spot-on, thank you.
I will need a minimum of 4,000 lbs. payload from the truck, to cover the pin weight of the 5th wheel and the passengers (2 people, 2 dogs) in the truck. Definitely need a one-ton SRW with 4000 lbs. payload, at minimum. And avoid carrying much fresh/grey water while traveling.
5th wheel will only be used for an occasional trip, not FT, so no need for it to be heavily loaded.
Since the vast majority of use of the truck will be as our daily driver, we do not wish to have a DRW truck.
