Me_Again
Nov 28, 2019Explorer III
DesertDogs wrote:
Do the long bed versions of 1 ton pickups typically have higher payload capacity than the short bed trucks do?
I've seen some 2019 RAM 3500 short bed trucks with around 4,100 lbs payload capacity - wondering it the long beds might add a bit more?
https://www.tfltruck.com/wp-content/uploads/2019/01/2019-ram-hd-towing-chart.pdf
For 2019 SB CC 4x4 GVWR is 11,800 and LB is 12,300. You want to get the optional Aisin transmission. It takes away a bit of CC.
For a LB you could go with the Andersen aluminum hitch and save a hundred pounds.
Again the real question is the 2600 dry pin weight that they say is an average. What is the actual starting point of the one you are buying. Washer, dryer, and/or generator?????
