billyray50
Aug 23, 2014Explorer
2oldnslow wrote:.
Putting the second battery ahead of the wheel well looks like the easiest way to go. Use at least 6AWG wire (4 or 2 would be better) to connect the two batteries. Put a pair of Anderson Powerpole connectors in line so you can disconnect the second battery to off-load the camper.
Source for Anderson Powerpoles:
http://www.powerwerx.com/anderson-powerpoles/powerpole-sets/sb120-sb-series-120-amp.html
How would you run the wires to house battery? Should i drill into bottom of battery compartment to run cables to set up in parallel or less invasive way to battery compartment.
44,066 PostsLatest Activity: Mar 14, 2015
