2oldnslow
Aug 24, 2014Explorer
billyray50 wrote:
How would you run the wires to house battery? Should i drill into bottom of battery compartment to run cables to set up in parallel or less invasive way to battery compartment.
Drill into the battery box only if you have to, and seal the holes well when finished. Look for a place you can tie into the existing battery cables outside the box if you can. The fuse block in the converter box is a good possibility.
Don't forget to put an inline fuse near the positive terminal of the second battery.
44,066 PostsLatest Activity: Mar 14, 2015
