bka0721
Aug 24, 2014Explorer II
2oldnslow wrote:Save your money and just purchase them at your nearest NAPA/AutoZone or any auto or marine supply store.
Putting the second battery ahead of the wheel well looks like the easiest way to go. Use at least 6AWG wire (4 or 2 would be better) to connect the two batteries. Put a pair of Anderson Powerpole connectors in line so you can disconnect the second battery to off-load the camper.
Source for Anderson Powerpoles:
http://www.powerwerx.com/anderson-powerpoles/powerpole-sets/sb120-sb-series-120-amp.html
tony lee wrote:Excellent advice and one I share often too. When one is not using the batteries frequently and are subject to Harsh use (S.O.C. below 12.1v) and infrequent charging fully, you are better off having a battery that won’t hurt as much when you learn you have just killed it. An $80 battery compared to a $400 battery is a substantial hit when they are not well cared for.
Nothing really wrong with the battery and you could just get another one the same to put in parallel.
Sure it isn't a true deep cycle or a legendary golf-cart battery, but for most owners not using their RVs full-time, these sort of batteries probably represent pretty good value for money - especially when they are often not looked after properly and rarely hooked to a quality charger capable of bringing them to close to 100% charged. They can last 3 years if looked after and then replaced cheaply - which is better than getting expensive batteries that may only last the same time if not looked after.
~DJ~ wrote:DJ brings up an important point. One should verify the dates on the battery or make sure they purchase batteries all at the same time and same manufacturing date code.
Something I've always heard. If you are going to run 2 batteries they should be within 3 months of age of each other.
Batteries are slowly diminishing with each use (cycle). Much like a Jar of Water. Each use you take a sip of the water and over a couple of years the Jar is not as full. Then you add another Jar alongside the older Jar, and they are hooked up to run together, they will only charge up to the level of the highest level of the old jar. Wasting all the additional charge ability level in the new Jar.
Also, you might find a pair of AGM batteries are able to be stuffed into your battery compartment on their sides. Allowing you to use the existing location and get more distance in your camping. This link is a good one to check this opportunity out; Mello Mike's Battery Upgrade Link Clicky
Having a dead battery on a very cold morning is a sad way to begin your day.
b
44,066 PostsLatest Activity: May 16, 2026
