- thundercloudExplorerNRALIFR
That is a cool idea. - NRALIFRExplorerI replaced the backup lights on my Lance with these.
Got them on Amazon. 27 Watts each. These particular lights don’t appear to be available any longer, but there are others like them.
I gutted the reverse light section of the taillights, fabricated a metal cover to replace the lens, and mounted the LED light to them.
t
Many times brighter than the old Halogen bulbs.
Between them and the LED docking lights, I can back into the darkest campsite, .........
Or my own garage when we arrive back home after dark. The garage door lift for the RV bay doesn’t have a light on it like a normal residential lift does, so it can be pretty dark inside.
I like them, they’re awsome!
:):) - brholtExplorer II
- JimK-NYExplorer IIThere are plenty of inexpensive and powerful LED lights. I would only wire them with an independent switch and use them only in campgrounds.
I have never seen the need. Maybe I would change my mind if I could find a decent rear view camera system that actually allowed me to see well and judge distances. - dirtyhandzExplorerI have the wife stand on the back step with a mag lite.
- Paradox123ExplorerI mounted two 45 W halogen “tractor lights” on the rear of my camper to the side of the jacks. They are wired directly to the back-up lights of the camper. They really light things up when backing into a space after dark. If I was buying today, I would get LEDs.
- PhotomikeExplorer III
skipro3 wrote:
Photomike wrote:
I was going to add an electric dump valve on my TCer so I could open the back tank dump when someone was tailgating, I don't think DOT has a rule for that one :B :h :S
What a brilliant idea!
https://www.etrailer.com/RV-Sewer/Valterra/E40A-8.html
As they say a Flush beats a Full house :B - Ski_Pro_3Explorer
https://www.etrailer.com/RV-Sewer/Valterra/E40A-8.html - PhotomikeExplorer III
Grit dog wrote:
I know, right? Got the DOT backup lamp cops out today......bad boys, bad boys, whatcha gonna do?
I 100% agree with the DOT code for rear lighting and it should be strictly enforced!!!!! You do not want to blind someone that is following too close. Of course I was going to add an electric dump valve on my TCer so I could open the back tank dump when someone was tailgating, I don't think DOT has a rule for that one :B :h :S
I had a couple LED's on the TCer wired up to the dash on the truck, they could have been stronger but they at least added some more light for the back up camera and when setting up camp.
44,070 PostsLatest Activity: Sep 18, 2026
