RoyB
Apr 12, 2018Explorer III
In our state the REVERSE LIGHTS comes under the DOT SAFETY LIGHTS purview meaning they have to be DOT APPROVED. The lenses are required to have DOT ID numbers and of course I'm sure there is spec on how bright they might be. They also have to be wired in to operate from you going into REVERSE and not be wired to an individual ON-OFF switch.
I got around all of of this by mounting my back of the trailer lights to rear sides of the trailer. I can't see directly behind my trailer anyway so having side lights worked out just as good...
Not sure if your state has any problems with your planned install or not. Just passing along my licensed state would do...
Some guys have done rear trailer lights mods only to have to remove them to pass their required SAFETY INSPECTION... Checking with your local DMV/DOT would probably be a good idea before dumping monies into your project...
My 5th wheel has the 8-inch scare light mounted high on the side of my trailer which is no problem here in this state. This has a separate ON-OFF switch on the inside trailer wall.
Google image
My off-road Starcraft RT14 popup trailer has a single 8-inch scare light mounted on the front of the trailer to be used with the front deck and this has not been any problem. It has a separate ON-OFF switch on the inside wall.
Google image
Mounting brighter REVERSE LIGHTS under my RT14 trailer rear bumper had to be removed because they did not have DOT approved lens and also did not come ON when going into reverse from my truck...
Rear lights looked like these
Google image
Just passing on a couple of my experiences dealing with DMV/DOT inspections...
Roy ken
Google image
Google image
Google image
Roy ken
