GordonThree
Apr 12, 2018Explorer
thundercloud wrote:
So if I go larger then the 20 watts do I wire directly to the camper batteries with a relay and tap into a reverse light that is already on the camper to activate the new backup lights?
Wire a relay into the truck's 12v system, unless you're mounting the lights on the camper itself. The objective is to not have to disconnect a bunch of stuff if you separate the two.
