thundercloud
Apr 12, 2018Explorer
GordonThree wrote:thundercloud wrote:
So if I go larger then the 20 watts do I wire directly to the camper batteries with a relay and tap into a reverse light that is already on the camper to activate the new backup lights?
Wire a relay into the truck's 12v system, unless you're mounting the lights on the camper itself. The objective is to not have to disconnect a bunch of stuff if you separate the two.
So the plan is to mount the lights to the camper itself. Having said that the only thing that I will have to disconnect would be the umbilical cord that I am currently using to connect/disconnect the truck to the camper (7 pin plug). Is this possible to wire everything to the camper and activate the new reverse lights when the truck goes in reverse?
