AnEv942
Apr 12, 2018Nomad
thundercloud wrote:
So the plan is to mount the lights to the camper itself. Having said that the only thing that I will have to disconnect would be the umbilical cord that I am currently using to connect/disconnect the truck to the camper (7 pin plug). Is this possible to wire everything to the camper and activate the new reverse lights when the truck goes in reverse?
Yes as you outlined prior if wanting to relay. Cant say 20 watts warrants a relay though.
I just use inexpensive sealed beam flood work lights in rubber housing mounted under bumper.
The factory Bargman backup 'indicator' lights 5' off the ground are pretty much useless.
I think they are 27 watts each (~2amps).
To wire I can access the left taillight wires thru an exterior cabinet.
Just dropped a lead to back of bumper, branches to feed both tractor lights.
