thundercloud's avatar
thundercloud
Adding Better Reverse Lights on a Camper
Has anyone every installed a set of reverse lights on their camper. I was thinking of adding some powerful LED lights from Rigid Industries or Black Oak LED. Wiring them in will be the biggest task. Any suggestions?
  • I put a pair of China's Best brand LED floodlights on the back of my trailer. They work great coming in to a dark site at night.
    Should be easy enough to do on a TC... If you can find the wiring harness for your Bargman 7-way, you can tap into the reverse line there, or the harness for a tail light and pickup reverse there.
    If you're looking at more than 20 watts of lights, consider using a relay to avoid taxing the existing lighting circuit.
  • Is the power of backup lights limited in Colorado? I’d check first.
