ShinerBock
Jun 24, 2017Explorer
mhawk4 wrote:
Thank you for all the info so far. I will be calling the Edge cts company Monday to check what they recommend for my particular truck.
I also came across a chip call TS 6 point performance. I know, I said I was not looking for tuners or chips, this one sounds pretty straight foward and has a good rep.
Any knowledge on this? Thanks
I can't speak for this particular product, but I will say that TS performance is a reputable company in the diesel word. They are not as big or have been around as long as Edge though.
Edge also makes a product similar to this for your truck called the Revolver. However, if you want to monitor things and tune your truck then I would recommend the Edge Evolution for your truck since it not only tunes, but it also is a monitor. Basically the Edge Insight CTS2 or CT2 is just a gauge monitor, The Edge Revolver is just a on the fly selectable tuner, and the Edge Evolution is both.
Contrary to most people's beliefs, a proper tune that doesn't add too much power is actually better for the engine in many cases. People ignorantly think that these engines are tuned with the best performance and longevity in mind first so adding any more power or tuning the engine will decrease the engines longevity. As a person who has worked for engine and truck manufacturers, I can honestly tell you that this false. Ever since the first emissions laws came in effect in the 70's(1992 for diesels), these engine are tuned t meet emissions. If they can't pass emissions then the engine cannot be sold regardless of their performance or longevity. In many cases, especially with modern diesels with EGR's, this tuning to meet emissions first actually hurt the longevity and performance of the engine.
Yes, if you add to much power without other modification to support such power or if you put a tune on from someone who does not know what they are doing then it can severely damage your engine and/or truck. However, in many cases a 30 to 50+ hp tune will actually help increase your engines longevity and efficiency..... at the expense of higher emissions of course.
44,071 PostsLatest Activity: Aug 30, 2026
