The biggest challenge might be getting 12 volts down to the cabinet. It's possible to fish wiring through ceilings, inside cabinetry, etc. I've done lots and it's not difficult but is time consuming.
Check to see if there is a hollow cavity on the underside of the cabinet over the bed. The usually do and you can run wiring inside and also install a recessed puck light too. You can surface mount a new switch under the cabinet near the light. You would need continuous-on 12 volts for a switch. If you can get wire down from the ceiling light, you would have this. If you have other things on the ceiling near the existing light like a vent, you can take the trim down and gain access to the ceiling cavity to fish wire.
A recessed LED puck light under the bed's cabinet would be a better choice as it will greatly reduce side glare from a surface mount light (like a standard pancake one). Try and check lumen ratings on LED lights before buying. Some list ratings and some don't, and some ratings aren't even close to what they claim. I bought 8 LED puck lights on ebay and they have worked well.
If you are handy enough and are in there doing some wiring, you might also look at installing a wall switch for the overhead light. I did that in our TT by fishing wire down the wall and across the ceiling. Sure is nice not having to reach up to the ceiling and over the bed. In your Clipper, you could either add a switch at the end of the upper kitchen cabinet or another one on the wall where I'm guessing there already is one at the entry door. There is probably a hole in the top plate of the exterior wall that you can get another wire into. Or you can cut or drill a hole inside the ceiling of the cabinet. You might even look at installing a few more puck lights under the cabinets - under the kitchen upper and the under the L-shaped on opposite side in addition to bed upper. Replacing the pancake light above the sink will eliminate annoying side glare and may give more light depending on the puck light you choose.
