Acei's avatar
Acei
Adding lithium batteries to pickup trucks
I'm looking for a possibility to turn a pickup into a small mobile office where my DW and I can do some work using laptops for hours if needed. I would use the rear seats with a small table surface hang from the front seat head rest for resting laptops. Looking to see if I can add something like 200Ah Lithium battery either in the cab or on the bed and also looking for ways to keep it charged.
Are there any elegant ideas on how to build such a system? Solar panels either on the roof or the bed cover? Can I use the truck's alternator to charge this battery when it is moving?
  • 200 amp-hours @ 12 volts
    80% useable
    160 amp-hours @ 12 volts = 1920 available watts @ 2000 cycles
    vs
    320 amp-hours of agm batteries @ 500 cycles
    Compare the cost per usable amp-hour. You may find the LI are not yet cost effective.
