Cvf0714ExplorerJul 31, 2016Adding new outletsWe are redoing the inside of the our 2005 Coleman bayside. We would like to add some more outlets. Any suggestions on doing so?
Golden_HVACExplorerJul 31, 2016How many amps is the service to the RV?How many circuit breakers do you have inside?What do you plan to run?You might also consider buying and leaving inside a 25' extension cord, and a computer type power strip with 6-8 outlets, then power this from the campground GFI 20 amp line, so you will not be overloading the main service.Good luck,Fred.
Related ContentAdding a 12v outletAdded 12V USB outletsadding 12v outlet and switchAdding more 12 volt outletBedroom outlets
