BB_TX
Feb 10, 2023Nomad
ScottG wrote:BB_TX wrote:thegabrielles wrote:
I will check the power on the RV, just and assumption but wouldn't the manufacturer spread the current out evenly on a camper that is prewired for 50amp service... I know what assume means. :)
You would like to think that wouldn’t you? I think most are on separate hots but you would not be the first to report them both on the same hot.
Interesting discussion. I still don't see why there is any need to balance. A 50A leg can easily handle 2 AC's even if something like a water heater is running. All three of those running at the same time would still be less than 5000 running watts - well below the 6000 avail. The RV's panel doesn't care - you could max out one leg and have nothing on the other leg without any heat, etc.
The NEC standard is for the normal connected load on a circuit breaker should be no more than 80% of the breaker rating. Two ACs, a water heater, and an outlet or two could easily exceed that.
44,070 PostsLatest Activity: Sep 18, 2026
