time2roll
Nov 06, 2020Nomad
I purchased mine at ultraheat.com
The 12v heaters pull a lot of amps so I primarily bought 120v heaters for the black and two grey tanks. The fresh water I went with a combo 120v/12v for extra heat if needed and to have some heat while in transit.
My waste pipes I wrapped with self regulating heat tape made for regular home use. Overrapped with some foam tape designed to insulate.
This all worked fine. I did have an issue with a fresh water pipe freezing in an inaccessible area when temps dipped to -10F and maybe a little more. I added a circulating hot water system to eliminate this issue.
Has all worked great for many years. Although have not been down that low since. Just got lucky that time.
Mine is a fair weather trailer with exposed tanks. Not much insulation but at least I had access to get the pads on easy.
