SDcampowneroper
Nov 06, 2020Explorer
Making an RV into a freezing weather capable weather unit is challenging. Water supply and discharge is one, not hard, by inulating and heating the hoses. The hard part is heating the 'house ' and dehumidifying so that moisture does not condense in the walls, which ruins all your insulation attempts.
However you attempt to use an rv in regularly below freezing weather, always vent moisture from cooking, showers, via fans, open vents.
Moisture from breathing, cooking and cleaning is destructive and contrary to effective insulation.
