BarneyS
Jul 09, 2019Nomad
If you are moving the whole hitch head down one hole then there should be no need to change anything else. The difference in angle between the hitch head and trailer will not change enough to affect the weight distribution since you have raised the truck up about that amount.
In case you want to re-check or re-do it here is a link to a detailed procedure for setting up your WD hitch. I think you might find it helpful. :)
Barney
Barney
44,070 PostsLatest Activity: Sep 18, 2026
