Hiking_Hunter
Jan 28, 2014Explorer
zackyboy3rs wrote:
What advantages will I see and use if I get one with the 50 amp?.... What about campgrounds that only have 20/30 amp sites?
Thanks
In addition to the advantages you listed of being able to run a heavier load, you will find that the 50 amp outlets are usually newer and are in better shape than the old 30 amp outlets (less arcing and poor connections than an old socket). Also, because they are wired with larger wire, the 50 amp source is better regulated and is less prone to low voltage caused by your neighbor's load - "cleaner power".
When you camp at a campground with only a 30 amp outlet all you need is a 30 amp to 50 amp adapter. Of course your source current will still be only 30 amps, but it's a simple connection. Same thing with a 20 amp source - just adapt it down. The 30 amp(male) to 50 amp(female) adapters that are available commercially will connect both hot legs of your 50 amp plug so all your circuits will work.
