LarryJM
Jan 28, 2014Explorer II
Bob Landry wrote:
I'll use a switch to parallel the two 30A panels when I have to run off a single 30A cord, then as was mentioned, it's back to the old days.
I'm not sure that is prudent since you will destroy things if you either parallel the panels or accidently forget to UNPARALLEL them when you hook up your dual 30A dog bone. Those 30A panels are going to be out of phase with 220V across the two hots in the panels.
Just a consideration...
Larry
