Artum_Snowbird
Jun 09, 2016Explorer
What size is the existing feed to your 12 volt panel? Maybe you can use that? I had a 400 watt unit in my previous rig that I just fed of the neutral and positive feed at the panel, and that put the inverter where I wanted it.
You might be able to upgrade the feed wires to the battery if need be. For our purposes, the biggest load was the coffee grinder at 160 watts.
44,066 PostsLatest Activity: Mar 14, 2015
