wally665's avatar
wally665
Advice from F250/F350 SRM Owners with HEAVY truck campers
Hi,
I am looking at purchasing a Camplite 10 Truck Camper next year. The dry weight is 2290lbs, however I have read adding the 4 seasons kit adds 500lbs so after loading it up I am thinking it will weight around 3000lbs at least.
I have a early 1999 f250 super duty crew cab long bed diesel rwd truck. While the window sticker says it was equipped with the camper/trailer package the spring code on the door sticker is "LA" and does not have overload springs in the rear or a sway bar. Per ford my max payload is around 1700 with a person in every seat. Since only my wife and I will be in the truck that will add more weight to the payload. The truck currently has 265 Goodyears rated for 34XX lbs I believe.
I dont want to bring up the debate of gvwr.
Does anyone else run a heavy camper on a f250/f350 srw? If so what modifications have you made to your truck?
As of now I am leaning towards the roadmaster active suspension, big wig rear sway bar and possibly airbags.
Looking for some advice from someone who has a similar rig!
Thanks!
  • Well the 500lb figure is what I read on another forum they could be wrong. The extended season package from camplite encloses the basement and heats it, tank heaters, thermal pane windows and extra insulation tthroughout. I don't see that adding more than 100lbs either. Ill be contacting camplite for specifics.
  • Op I know this does not answer your question but What exactly is included in 4 seasons camplite? We have one so am curious. Thks!
  • I had a 4000 lb camper on a 2005 F250 (had a 9800 GVWR) while towing 8000 lbs. Get an actual weight of your rear axle to see how much you have left with the current wheels. If you have the 10.5" Sterling rear axle, it is good for 9750 lbs if properly outfitted and is not anything to worry about. Since you do not have an upper overload spring, consider just replacing your spring pack with a heavier one. If it will need more help, then you can add StableLoads or air bags. You have close to 7000 lbs of tire rating on the rear axle - If you start to get close to that number, the rims and tires need to be upgraded and this is the time to look at 19.5" wheels. Since these wheels are heavier, OEM shocks will not have enough dampening, so you need to change to heavier Rancho or Blistien models at this time. I had the OEM stabilizer bar on the front and rear of my truck and never changed them out. Since you do not have one, look at the Roadmaster bars before the Hellwig.
  • Two primary limitations in terms of payload are the leaf springs and the rims/tires. The first can be overcome with SuperSprings and the second with the use of 19.5 rims and tires. Cost of SuperSprings is $500 and for 4 19.5 wheels figure on $3500.
    Or you could get a lighter camper that weighs 2400 lbs. or less and get buy with E tires like the Nitto, Toyo,and BFG that are rated for 3750@80 PSI or more and will work with a 3400 lb. camper load (fully loaded).
    A 4-season kit will add at most 100 lbs. as all that is done is double pane windows and a tiny bit of insulation.
    Check out the Lance campers which are some of the lightest you will find and very well designed. A brochure with specs can be downloaded from their website. Good idea to get a camper that can hold two batteries and the optional solar panel is worth getting as well.
