covered_wagon
Apr 14, 2016Explorer
The camper should ground thru the tie downs. Check that too.
Grounding should be at least the same size as the charge wires
If a fuse goes it usually does not partially go but blows completely and disconnects all current unless there is corrosion present on the terminals.
