Perrysburg_Dodg
Jul 14, 2016Explorer
What gear ratio does the truck have now, 3.92 is the tow gear in a Ram 1500 most came with a 3.55 if it was a dealer stock order. Being a 2WD truck the cost should be under $2000 out the door. I would go to a shop that does driveline only work if it were me. The other option is a complete rear axle swap from a 3.92 truck with low miles. I did this once to a Nova I owned was a lot easier then changing out the gears IMO.
As for the tire and wheel size not sure how much real help you would get going that route.
Don
Don
44,067 PostsLatest Activity: Jun 05, 2026
