Turtle_n_Peeps
May 24, 2014Explorer
hertfordnc wrote:
I came very close to buying a Dodge 3500 Cummins this week but the family didn't love it so I let it go. In my research on other diesel trucks under $8000 the Diesel Burbs from the 90's come up a lot, and cheaper than comparable Fords & Dodges.
In further research i find people on other forums saying there are some bad ones to avoid. I know i don't want a 700R4.
So, I would be grateful for a summary of what to look for and whether or not folks here think one of these would be a good choice.
THe goal is to have a 20+ mpg daily driver that can comfortably pull my 6000 lb trailer up the mountains (East Coast mountains)
Thanks
The 700R4 never came in a 6.5 turbo. The 6.2 N/A, yep, but not the 6.5.
I own a 6.5 and really like it. I even like driving the 6.5 truck better than my LBZ Dmax.
That being said. The 6.5 has some common problems.
#1. GM thought cast iron was gold in the day and got cheap on the pour. This made them prone to cracking.
#2. A super common problem is with the PMD. No real big deal on this one because the aftermarket makes a real nice one with no problems.
#3. They had some cracking problems with the blocks in the late 90's.(2 years I think? 97 and 98 IIRC?) Again, not many were affected but it did happen.
#4. With no intercooler and the power they put out, they tended to get hot in hot weather. Again, this was pretty much fixed with duel thermostats and a better pump in later models.
All that being said most of the problems show up when you push them real hard in hot weather. They were fine for light duty work and that is what they were designed for.
You won't get 20+ MPG in a burb. 18 is about it with a burb. Trucks got better mileage than burbs and my gets 19. It's no speed demon with only 200HP. But it does get the job done with my 7K TT and gets 12 MPG doing it.
I still tow with mine and it runs great at 175K. I did update the head gaskets and put ARP studs in the block and a new style aluminum radiator.
All in all the Cummins is light years ahead of the 6.5 as far as dependability and robustness of design. Plus with the Cummins you can turn them up to get good power out of them. If you do that with the 6.5 you can start breaking blocks and heads.
Bottom line is, some people like them and some hate them. I can't tell you what to do but I like mine.
44,056 PostsLatest Activity: Jan 12, 2020
