RoyGBivUV's avatar
RoyGBivUV
Adzel...real world benefits? Drawbacks?
I've seen a few manufacturers tout the use of Adzel, which appears to be a world of improvement over marine grade wood in terms of weight. What real-world benefits does that translate into? Any drawbacks?
I figure a natural benefit might be in opening up some tow vehicle options...How significant of a jump in weight is it? Are we talking about shaving off a 1000+ lbs, or is it more like marketing fluff?
Does it make a dent in terms of towing fuel efficiency I would imagine the largest factor in that is drag, and that would be more directly related to frontal surface area vs. weight.
Insulation-wise, what's the actual *difference* in R-value compared to plywood? Sailcloth canvas?
It doesn't strike me as a substantial material from a structural perspective, which means the blocking and structural elements used at corners & edges need to be something else, yes? As a flooring material...where all the millwork gets nailed down into...I've got to imagine that it's not the best choice unless alot of work goes into blocking out structural elements under it or inlayed in the material.
