brulaz
Sep 27, 2013Explorer
Gdetrailer wrote:
NOT UV resistant, MUST be “protected” by another UV safe product like paint or UV barrier.
NOT readily “glued”, conventional glue laminating does not work.
It must be WELDED (IE MELTED) to the adjoining surfaces,
OK, but where does the separate fibreglass panel come in? Or does it?
I thought Azdel was pressure laminated to a fibreglass panel in the RV factory, just like filon is laminated to luan. Or does it come from the Azdel factory with some sort of pre-applied Gel coat? Like filon except structurally more stable so not requiring the luan backing?
And when they laminate the Azdel to the foam+Al interior of the shell, they don't use glue? Just high temp+pressure to melt everything together?
