WoodGlue
Sep 27, 2013Explorer
Gdetrailer wrote:
While it may be “waterproof” and not damaged by water, the same desirable characteristics can also be very bad since it must be FULLY heat sealed (welded) to the adjoining materials it can become a trap for ANY moisture which finds its way in during or after lamination. In other words if the process does not fully seal the wall or if the wall develops a way for moisture to get in it may be trapped inside. This trapped moisture can do several things, FREEZE causing internal delamination (separation from structural materials) or create a very ripe breeding ground for MOLDS to grow
Exactly why Lance uses a climate controlled room when dealing with Azdel.
WoodGlue
