Cup fan wrote:
Something I would be curious to know would be how the attitude of the trailer behind the TV affects mileage. I see a lot of trailers going down the interstate that aren't level. The nose
of the trailer is often much lower than the rear, perhaps due to improper hitch ball height, or improper springbar adjustment. I know for me, proper hitch set-up is huge as far as handling is concerned.
Nose up or nose down also affects mpg, as you are now exposing either more roof area (towing nose down) or more bottom area (towing nose up) to the air when towing. If perfectly level, you only have the nose and whatever objects are above the roofline.
On the flip side of that, being slightly nose down gives more stability while towing.
