Ron-C's avatar
Ron-C
10 years ago
Aerodynamics Matter !!
Hello All. First post here... wanted to share some data on aerodynamics.
I am designing an ultralight (under 100 lbs/ft) small travel trailer and wanted to find out the effect of shape on aerodynamic drag. I modeled up 2 trailer designs using SolidWorks CAD software then applied CFD (Computational Fluid Dynamics - a virtual wind tunnel) to test them.
The baseline trailer was a box shaped design with slightly rounded corners - essentially flat nosed cargo trailer. Then I created 4 versions of a swept profile trailer steeper at the front and with a longer sweeping tail in different widths.
Results showed that a swept profile trailer 7" wider than the baseline box trailer at the same height would have 45% less drag force. Looking at it the other way around, it would take almost twice as much force to pull the box trailer!
My conclusion, the shape of the trailer is way more important than the size of it. This means that a larger trailer would require less fuel to pull if it is the right shape.
There are lots of other factors including the shape of the tow vehicle, speed, temperature, etc. but this is at least some food for thought.
Now I am working on a developing an aerodynamic shape that is functional :)
Ron
