Grit dog wrote:
^Nevwr hauled big things in a pickup, eh?
Ragged edge?
You saw the pic on the same truck as yours but 20 years older, right?
I can assure you it was not on the ragged edge and your truck is vastly stronger in every way (except the engine is just as stout in the 2nd gen) than the 2nd gen.
But they make lots of smaller campers than that, so whatever you're comfortable with is the right one.
Actually the AAM rear axle under a new Ram 3500 is rated at 10,120 pounds by AAM, and the Dana 80 under that 2nd gen Dodge is rated at 11,000 by Dana.
Most on here believe new trucks are heavier duty, that’s not necessarily so. They just put bigger numbers on the glovebox.
That 2nd gen 3500 is as stout as any pickup. That’s the same rear axle Ford used to use in the F450.
This is why I’m always telling everyone the so-called “ratings” are not gospel. They’re marketing hype, numbers not calculated by the engineering dept.
You have to look at the actual parts.
