Procrastinator's avatar
Aug 15, 2018
After 17 years finally happened (tire blow out)
We have been yanking one type or another trailer around the country for over 17 years now. I have been very diligent about keeping tabs on my tires. 4 years is about the longest I will keep a set of "chinas" on a trailer. The previous trailer took six maxxis tires.
As my tires were hitting the 4-year mark, I had been shopping already with plans to replace over the winter. We didn't make it.
Northbound on I65 just south of Nashville, we lost the rear driver's side tire. Everyone in the cab heard it. Thankfully, I have made a habit of "over trucking". I am currently towing a 10,000 trailer using a Hensley Hitch and an F350 dually. So we never lost control or had sway problems during the blowout. I had to travel over a mile on the shredded tire due to the absolute refusal of anyone on the road willing to allow me over to the shoulder even as I slowed to about 45 with my hazards on.
After replacing the blown tire with a spare we were able to get back on the road. I know had no confidence in my remaining tires. Since it was late on a Sunday with nothing open and at the risk of whatever the dealer had in stock, we decided to risk it and continue on. 335 miles at 55-60 mph. I normally cruise around 65-70 mph. I now understand why some people choose to travel at that speed as I never had to worry about passing anyone; therefore, less stress. However, watching the miles to go on the gps never ever go down was stressful. After the first hour, it seemed we had traveled only 30 miles.
We made it home safe, and the next day it was time to survey the damage:
-took out my sewer discharge pipe
-took out a clearance light
-ripped off the fender skirt
-the tire ground out the fiber floor cloth covering, the luan, and the styrofoam. It did not damage the subfloor.
I checked all my tanks connected to the discharge pipe and all were fine with no damage.
I then replace all four tires with Goodyear Endurance (test mule here). I have been busy online buying replacement parts and I will be back up soon.
After fixing the underside I am thinking about welding some metal to the frame above the tires and then undercoating it all to prevent any problems again.
All in all, we were all safe and no one got hurt. It just made my trip more expensive and more time consuming when we got home.
Safe travels.
  • Seventeen years without a blowout is a good run. Thanks for the reminder to us not to procrastinate on important things like tires.
    I'm seven years with no blowouts but I'm only averaging 1,000 miles a year (a lot of local camping) and don't drive over 60 mph (yea, I'm that guy) so not a lot of wear and tear on the tires as far as mileage goes. The TT is also stored where it doesn't get a lot of direct sunlight which probably helps preserve the tires.
    Hopefully your next 17 years will be blowout free.
  • wnjj's avatar
    wnjj
    Explorer II
    I don't think I'd assume the tire "went bad" due to age or anything else really other than something it hit. There's no reason I wouldn't trust the other 3 for at least the rest of the trip, other than the fact that I would not have a spare anymore so another flat would be bad news.
    As for getting people to move, maybe turning the hazard lights back off and using just a turn signal would better communicate your needs. Then, if that doesn't work do as the truckers do and just start moving over. You're bigger than them. ;)
    Bummer about all the damage but as you said at least you're all OK.
  • Do you know what you hit that took out your tire? Once it is down an shreds they all look the same.
    Mine was a road hazard I never felt, that put a baseball sized dent in the rim and broke the spring. The shredded tire did little TT body damage but it took out both axles. It sure did smoke a lot. The real problem was it was a month old D rated upgrade to my tires.
    The insurance covered everything including a new D rated tire.
  • Do you know what caused the blowout?
    Time for a TPMS!
    Next time consider Michelin XPS Ribs.
  • naturist wrote:
    Hard to believe other drivers wouldn't let you pull over anywhere. I guess the self-centeredness often mentioned has reached new depths, but there it is.
    I have no problem believing that. Drivers don't have a second to deal with your problem, they have smartphone duties that take precedence.
  • Glad you are OK. Camper and tires will get fixed. Consider the slower speed in the future. Less stressful ... I agree!
  • Good news nobody got hurt. Hard to believe other drivers wouldn't let you pull over anywhere. I guess the self-centeredness often mentioned has reached new depths, but there it is.
    Gosh, who need that kind of grief....I guess that's the price you pay when you are a "Procrastinator"......:)
    Anyway. Glad you made it home safely. I'm going with Goodyear Endurance also.
