TNRIVERSIDE
Aug 30, 2015Explorer
I swapped out the factory cover on my F150 for the Mag-tech rear end cover. The first benefit is I can now Chang out the lube without pulling the cover. Second benefit is the increase in lube capacity. This is somewhat misleading because some of the increase is due to filling the cavity to a higher level. Just below the axles. The larger cover allows additional lube too. Third benefit is it should run cooler. On a recent trip I used an infrared heat gun to compare my temp to my buddy's F150 pulling a similar TT. Mine was just 10 degrees cooler. Not much difference. And it looks good.
44,057 PostsLatest Activity: Mar 12, 2026
