milleda31's avatar
milleda31
Aftermarket wheels
Gentlemen,
I have a 2016 Ford F350 Lariat LB DRW and a 2008 Lance Max981 camper.
Suspension and current wheels and tires are all stock (Alcoa wheels). I want to switch out the wheels and tires for some aftermarket 20" Fuel's or Vision's. The ones I like require no spacers. The Fuel's are rated at 2500 lbs. and the Vision's are rated at 4300. I would be mounting some Toyo Open Country tires on them.
Clearly the Vision wheels will handle the weight. What do you think about the Fuel's? Also, I sometimes pull a 3500 lbs. boat behind the setup. All my truck gear is Torklift. Camper probably right at about 4000 lbs.
Thoughts? Thanks in advance.
https://www.visionwheel.com/wheel/7210/VisionHDTruck/Trailer/401%20Rival?finishID=591
http://www.fueloffroad.com/wheel/11115/fuel%2Ddually%2Dwheels%2Dtriton%2Ddually%2Drear/?finishID=329&lugs=8
  • 3 tons wrote:
    First off, Safety matters and the majority of the ‘racy’ aftermarket wheels out there are of the cheap cast variety designed more for looks rather than loads - go forged like your robust Alcoa’s and stay Safe...
    3 tons
    Agree 100%
    I used to haul my Lance on a 2001 F350 7.3 SRW. I upgraded the wheels on that vehicle to Vision 19.5" rated at 3900 lbs. I also ran load range F tires on it.
    https://www.visionwheel.com/wheel/867/VisionHDTruck/Trailer/81A%20Heavy%20Hauler?finishID=103
    The Visions in my first post are rated at 4300 lbs. and add the fact that my current truck is a DRW. I am assuming that I'm good to go, correct?
  • 3_tons's avatar
    3_tons
    Explorer III
    3 tons
  • I’d look at American Force wheels, and also consider 22.5s.
  • jimh425 wrote:
    First, what is your goal? Are you simply trying to make your DRW look cool or something else?
    Yes...simply for appearance.
  • First, what is your goal? Are you simply trying to make your DRW look cool or something else?
