- chuckftboyExplorerA larger wheel will take a larger tire so expect your speedometer and odometer to be off considerably. You could use a good GPS to monitor speed
- C20ExplorerYou might check boar wheels. Not sure they are for your application but they are awesome on trailers.
- RLS7201Explorer IIOnce you consider the cost of 19.5 tires and wheels. Think about the best 235/85R16 tire for your MH. Michelin XPS is the tire Ford picked as OEM, for a reason. The XPS has all steel cord construction and that helps eliminate tire side wall flex. I run nothing but Michelin XPS tires on my coach with never a problem. The drive and handling is good.
You current 235/85R16 tires are 32" in diameter. Try and maintain the diameter if you insist on changing wheel size.
Richard - jdc1Explorer IIThe biggest obstruction might be the front end wheel-well. Do a clock-to-clock turn, having someone make sure there is room for the taller tire.
- Edd505ExplorerTry here Hi Spec Wheel
- Dutch_12078Explorer IIIRickson Wheels has the conversion wheels for $261.87 each:
19.5” WHEEL & TIRE UPGRADES FOR MOTORHOMES ON 1997-Back FORD F-53 CHASSIS - LwiddisNavigatorCheck the max wheel weight carefully for whatever you choose.
