gitpicker2009's avatar
Nov 07, 2015
AGM battery advice
Well, it looks like the two Interstates are cooked. I'm considering upgrading to AGMs.
Looking at some of the pricing, like the EXIDE brand is scary, but OPTIMA lists a nice 750CCA batter for only about 175.00
Any experience or advice?
thanks
  • Optima batteries are vibration resistant, but are relatively low output. I use them because I drive gravel roads. Standard batteries would only last 18 months.
  • $ for $ they'll outlast flooded cells. I just replaced a 7 y.o. AGM battery in my TT. Unfortunately it was a large 4D and the replacement was super expensive so I went with a flooded cell replacement.
    The Optima has good press so they should work well.
    Two caveats would be: 1. make certain that your converter/charger will work OK with the AGM. If it's only a few years old, it's probably a 3 stage and will be fine. If it's from the 90s it could be a 2 stage and will be an issue. 2. The AGMs are taller than their flooded cell cousins. Be certain they will fit. When I had my Lance 981 I wanted to go to AGM but they wouldn't fit in the compartment.
