I heard that a AGM battery is not recommend for 2017 Ford F350 because the alternator will charge them wrong and it short the life of the battery.Anybody know that?
AGM batteries can be charged at 40% of lost amps vs lead at 25%,gel at20%. So if you have too small if a power source, the battery will not charge correctly. Or you will blow up power source, ie alternator because you are working it too hard This is a big issue in boats, with house battery makeups many times bigger than land yachts.
