Ramp_Digger
Mar 31, 2016Explorer
dave17352 wrote:x2 All I can add is I also only use the air bags to level side to side when necessary.
These 1 ton trucks are meant for hauling weight. the overload springs are meant to be engaged when hauling heavy weights. With the air hauling the load it has been my experience that you get way to much sway. I found when I had air bags there main advantage was to balance the load. The springs need to be engaged considerably to handle the sway. JMHO
44,070 PostsLatest Activity: Jul 01, 2022
