maxum1989
Dec 14, 2014Explorer II
Gripnriprod wrote:
This from Tire Rack when discussing tire pressure: "The rule of thumb is for every 10° Fahrenheit change in air temperature, tire pressures will change about 2% (up with higher temperatures and down with lower)."
I would add that the air bags are "relaxing" after initial inflation. Continue to monitor the pressure. If the pressure doesn't increase when it warms up, you may have a problem.
excellent post. Thanks.
44,056 PostsLatest Activity: May 04, 2014
