Reddog1
Dec 15, 2014Explorer II
maxum1989 wrote:Reddog1 wrote:
Does it take much to understand that super springs have nothing to do with Air pressure?
Wayne
Molderator
Sure, but how about a "Lets keep it on track" kind of approach instead of just deleting without warning. And, considering Super spring offer a very similar remedy to suspension issues like air bags, one could argue that it is fair that they are brought up in a discussion like this. As the OP, I responded to the post you thought was off topic as I thought it was relevant.
My main beef was that so many threads on this forum turn very nasty and run on for pages with no moderators around and you chose this very civil one to throw your weight around.
Of course, this post is off topic as well so I guess it will be deleted. But, make sure yours disappears too as it has nothing to do with the question I started this thread with.
Very seldom if ever have I responded to a post like I am going to respond to this one, so consider yourself special.
1 The post I quoted above is a direct attack on me, as a person and moderator.
2 If you are aware of a Forum you would be happier with please enjoy it.
3 Your "beef" is not valid to me as the only Moderator on this Forum. With 338 post on this forum since you joined (03/29/2006), I question you have any idea as to how this Forum is moderated. Please refer to my second comment.
4 I am of the belief, most if not all participants on the forum are adults. As such, the expectation is to be reasonably aware that post can and will be deleted without reason. Fact is, I posted the reason I deleted posts. I thought my post was very clear and need not be posted on every thread.
5 As a moderator, I will not accept an attack on my character. If you disagree with my moderating, so be it.
6 No mater how hard I try, I see no connection between the post on Super Springs and the OP "air bag pressure and temp change". No doubt, it is not unusual for post to drift away from the OP, but the Super Spring post did not drift, it was Off Topic.
7 I made this post on an open forum only because it is a response to your post and attack on me on an open forum. Should you wish to continue this discussion, I suggest you do so through PMs. I will delete any further Off Topic posts.
Wayne
Moderator
44,056 PostsLatest Activity: May 04, 2014
