RinconVTR wrote:
The bags do not affect the WDH weight transfer when they are not used excessively. Which is why I set up my WDH first and add only enough air to increase spring rate with ride height changing only a fraction of an inch. I run only 10-15psi in my generic Firestone bags.
That is the key IMHO. A more drastic ride height increase will change the angle of the bars and affect the weight distribution.
Generally, I would adjust the WDH (by checking front end rise or weight) after every suspension change, like a bag psi increase. Especially when installing a new wdh or suspension mod.
But if you know your system well and only make small changes, like RinconVTR ... seems like there shouldn't be any issues.
