I should point out that I have not used the Firestones, but a friend of mine swears by them. With that said, I have had two Ford trucks and installed the Air Lift systems on both. With both I also used the systems without the on-board compressors, opting to adjust the air levels with an outside air pump. My advice...use the on-board compressor. I have used both the Air Lift compressors with the plumbing that runs into the cab and the new WirelessOne system. The older style worked well and I had it set up as the dual system. The WirelessOne system is plumbed so both bags have the same air pressure.
Having used those systems as described I have two comments. One is that unless I was carrying a top heavy load like a Cabover camper I like the WirelessOne system. It's a slightly easier install and works great. Secondly, having the on-board compressor is a great feature that makes it a breeze to adjust, without even having to stop. Also, you don't have to get out pumps or stop at various locations to make adjustments. Along the same lines, the final selling point for each was having to adjust the air pressure at a gas station, and the pressure gage/air fitting tore the Schrader valve out.
Adjusting the pressure to be used is simple and only requires a measuring tape. Measure the height of a point above the ground at the rear of the vehicle when unloaded. Then hook up the trailer to the fully loaded vehicle. Add air to the air bag system until the height at the point previously measured to is the same. Enjoy and you will also love the system. Expect it to take longer to install than those who have cool tools like vehicle lifts. It is always slower to do it laying on the ground.
