- Have to agree with Bryan if that's the trailer you are towing with your truck...
Add whatever you feel you need to, but that's a BA trailer!
Good luck!
Mitch - WNYBobExplorer2X on tires (probably "P") and then OEM shocks (I went with Blistein's)
I also installed Air-Lift bags, but use them for leveling only. - carringbExplorerThis is a 35' trailer with a GVWR over 11,000 pounds....
You can keep bolting helper items on your truck, but at the end of the day, it's still a half-ton with half-ton axles, brakes, frame, and powertrain. - lawrosaExplorerWhats your issues?
If the GM reciever is still attached to the bumpers I would start there. Then the crappy GM shocks .
Then tow and make a determination.
