Colo_Native
Dec 02, 2015Explorer
Air bags
I picked up the FW today and measured the drop on the rear and it went down 3" not the 1 1/2" I guessed before at what point do you considerer air bags?
Colo Native wrote:grampscamper wrote:
I have the camper package on my F250. When I would hookup the 5th wheel the truck would settle into the helper springs. I added air bags earlier this year and saw a noticeable improvement in the ride. Now my truck sags only slightly with about 40 lbs. in the bags. I put enough air in the bags so I'm just off the helpers. The truck is level now and I had to lower my hitch so the 5th wheel is level.
Which brand air bags? Do you have a on board compressor?
Bedlam wrote:
If you have the camper package with the upper overload springs, you just need the Torklift upper StableLoads to engage that spring sooner. If you do not, I would suggest Timbrens or SuperSprings to get greater spring rate. Bags will help some of that sag, but 3" worth of sag will be hard on the bags and most likely make your truck mushy and porpoising.
I do have the camper pkg.
