I just bought a
Milwaukee M12 inflator. Great little inflator. Perfect for "topping off" tires and blowing up inflatable toy. Max pressure is 120 PSI. For large tires (like Class A's) it would take a long time to fill a completely flat tire. Likely 3 or more batteries
(M12 lithium ion).
The best feature is, just screw it on
(brass Schrader valve adapter), set the pressure on the digital gauge and press start. As I said, you had better have 1 or 2 spare batteries and a way of recharging them when you are on the road.
TIP : You need to make your own adapter to fill large inflatable toys. But a 3" grass tire valve (cheap on eBay). cut off the end where it would normally attach to the rim. Deburr inside and out. Mini blow gun !
