SDcampowneroper
Oct 07, 2015Explorer
To properly blow out an rv with air, you need a compressor capable rated at 4+ CFM @ 90 psi.
Compact Jobsite compressors are generally inadequate to supply the volume of air at pressure needed to blow a rig dry. They are designed to power a couple of air nailers with a lower supply demand.
For the same money, go get a 30 gallon 1.5 hp from your box store that will handle all your needs and outlast the compact.
44,071 PostsLatest Activity: Aug 09, 2026
