wing_zealot
Oct 08, 2015Explorer
RoyB wrote:The problem with this compressor is it has no air regulator. If not careful, you could inadvertently put 150 psi pressure on your water lines and blow them apart. I wouldn't recommend that for anyone that doesn't know anything about air compressors. And it certainly won't be any use for his deck project.
For me the 12VDC TANKLESS 150PSI portable Air Compressor works the best. Most of my camping is OFF-ROAD without 120VAC PEDESTALS.
Purchased from AMAZON
I can sit my small tankless compressor on the tail gate of the truck and direct connect the 12VDC CABLES to the BATTERY BANK on the trailer. The AIR HOSE is long enough to walk around my trailer and truck tires from this position.
I use my 12VDc Compreesor for blowing out the water lines in my trailer by connecting to the CITY WATER PORT using an AIR COMPRESSOR air adapter...
Being a TANKLESS model the air compressor is slow bringing up the resulting air pressure and works ideal for me to start the air compressor and walk inside the trailer to open the sink spigots etc...
The 150PSI Air Compressor airs up all of my Truck and Trailer tires just fine...
I store this small footprint air compressor in its neat carry bag under the rear seat of my SUPER CAB truck.
Roy Ken
44,070 PostsLatest Activity: Sep 18, 2026
