rbpru
Oct 08, 2015Explorer II
Perhaps the biggest problem with the compressed air approach is you have to know the plumbing layout in your TT.
If you open the low point and blow out each individual faucet chances are you will drive the water out of the lower point. However, there is no guarantee that there is not some point in the system where the water line tubing sags creating a gathering point for the water droplets left in the pipe.
My TT water system is rather simple, the kitchen sink, bath sink, tub, shower and outside tap are all within 10 feet of the low point drain and I can remove various panels to check for sag points. Others are not so simple.
Still, after I have blown the pipes, I hook the pump input to a bottle of anti-freeze and pump it through to each facet. I need the anti-freeze for the P traps anyway. It is kind of a belt and suspenders approach but it has worked so far.
44,070 PostsLatest Activity: Sep 18, 2026
