Wes_Tausend
Oct 10, 2015Explorer
wannabervin wrote:
I'm thinking about doing my own winterizing this year. I'm also planning to resurface my deck at home. Each job raises the possibility of purchasing an air compressor. But I know very little about air compressors. Can one air compressor be powerful enough to drive nails but also be dialed back to blow out water lines in my TT?
I would actually recommend one of the economical pancake compressors similar to the ones shown by others. A one or two gallon unit often sells for about $50 on sale at Menards or other discount stores. I have used one I carry along camping to purge my TT and it works great with just a few extra moments required to wait for the air tank to refill after each faucet/line. The sudden full air rush of even a small tank is enough sustained "wind" to blow the narrow TT water lines clear.
The 1st reasoning is that you have a far from commercial use planned for the unit, so a HD super compressor doesn't make economical sense. I agree, an occasional deck, or once-a-year RV purge doesn't really merit blowing a lot of extra cash on such a tool (save it for fuel). The other reason is that there is no longer much difference between small HD high cycle-rate compressors and small average consumer grades. Lastly, they are easy to store.
I do generally use a larger 220 volt shop compressor that puts out some 14 cubic feet of air at 90#, but only because it is quicker to do my lawn sprinkler system which I do at the same time. I found a good deal on that too, only paying about $300 on a closeout special. A penny saved is a penny earned... to pay for camping fuel.
Offhand, even the modern RVs have improved in freeze resistance. Most use rubbery Pex water lines now, and these lines are very resistant to breaking from ice swell. So low points aren't a big deal if some small amount of water still remains. Hard plastic fittings, like valves, must be dry though. They are all high except for special low point drains if you have them (fresh water tank dumps, sewer dump drains etc, so I leave those open that remaining water cannot collect there).
Wes
44,070 PostsLatest Activity: Sep 18, 2026
